Ammeter installation
robb420in323
Copper - Posts: 101
Posted: July 14, 2004 at 1:01 PM / IP Logged
Can i just creat a loop with the unused portion of the fuse block in my stereo for an ammeter. or does it actually have to be inline with the amp??
Please help..
Thanks!
Hunter S. Thompson for sheriff
auex
Platinum - Posts: 5,041
Posted: July 14, 2004 at 4:09 PM / IP Logged
Must be in line.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
robb420in323
Copper - Posts: 101
Posted: July 16, 2004 at 8:35 PM / IP Logged
Why cant i just install it in a power wire loop created off the fuse block? WHat will happen?
If its inline wont it weaken the power wire strength.. the weakest link??
auex
Posted: July 16, 2004 at 9:08 PM / IP Logged
The only way to measure amperage is in-line. And yes it cause a loss. I don't really understand why people even want these.
robb420in323
Copper - Posts: 101
Posted: July 17, 2004 at 6:56 PM / IP Logged
So we can tell how much Amps are Power Amps are drawing.
Indicates any improvment from Electrical System upgrades..
Good enough mr blind amp?
auex
Posted: July 18, 2004 at 12:06 AM / IP Logged
But why exactly, and specifically, do you need to know how many amps the amplifier is drawing? For most people this information is absolutely useless, just like driver sensitivity. Even if you had a need for this information, you still shouldn't need it all the time and would only used it for tuning information. Also, how does an ammeter tell you if electrical system upgrades help audio performance, the amplifier's current draw will be just about the same whether you alternator is putting out 85 amps or 300 amps. If the amplifier manufacturer is a decent then their spec sheet will tell you exactly how many amps it can draw.
Sorry, just don't understand the need for this on an amplifier.
robb420in323
Copper - Posts: 101
Posted: July 18, 2004 at 10:01 AM / IP Logged
Your right. I just picked it up for 6 bucks at CT..
But i dont want it inline, i want it monitoring the whole system in the trunk..
Theres 2 spots on the fuseblock  i can loop, cut the loop , put the meter in...
Are you telling me that theres no Amprage in a power wire connected to the batt at both ends??
backinblack_gp
Member - Posts: 21
Posted: July 21, 2004 at 8:28 PM / IP Logged
Look around for a digital ammeter that uses a shunt bar and sense leads.  It's a little safer than running inline...
robb420in323
Copper - Posts: 101
Posted: September 21, 2004 at 8:07 PM / IP Logged
But theres no amperage in the unused portion of my Fuse Block???
Teken
Gold - Posts: 1,492
Posted: September 21, 2004 at 10:47 PM / IP Logged
I hope you do realize that the current you will be measuring is dynamic, and not static.
If your intent was to measure the current output of the alternator, then that would be something worth doing.
But to monitor the amplifier, that isn't neccessary. As
backinblack_gp stated, you would be wise to install a digital ampere meter, which uses a shunt.
Having another high current transferring cable, will only cause you more grief.
Regards
EVIL Teken . . .
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
