98 honda radio and cig lighter dead
caltwo
Posted: February 01, 2005 at 5:57 PM / IP Logged
need help to source out my problem. the car radio(not a factory installed honda radio,but a honda radio none the less-replacement for stolen original)and the cigarette lighter(mobile phone charger )no longer work. Both operate on the same 20 amp fuse, which is fine-not burnt out. i have been told there is no relay controlling this circuit. can anyone help me source out this problem-p.s. no factory code on radio as it is a replacement. thanks
caltwo
auex
Platinum - Posts: 5,041
Posted: February 01, 2005 at 6:43 PM / IP Logged
Have you tested every fuse, including those under the hood?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Moderator - Posts: 12,488
Posted: February 01, 2005 at 7:01 PM / IP Logged
As in past recommendations for fuse testing, make sure you use a DMM to test for burned fuses.
shnackelberry
Posted: February 08, 2005 at 2:16 AM / IP Logged
the fuse you need to replace is under the hood
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
