Voltage Stabilizer
Betkers
Posted: May 13, 2005 at 5:22 AM / IP Logged
Hi all, I am new here. This is my first post here and I hope you guys can help me. Recently I try to DIY a voltage stabilizer which is connected to the car battery. But during my research, I found that there's lots of different diagram. Some have more than 50 capacitors but some only got 3 caps! So, which is more precise and what's the best circuit for the stabilizer? Thanks
Francious70
Silver - Posts: 629
Posted: May 13, 2005 at 9:39 AM / IP Logged
Depends on what SIZE caps your using.
Paul
Betkers
Posted: May 14, 2005 at 8:14 AM / IP Logged
4700 uF (3pieces), 3300 uF (3pieces), 1000 uF (8 pieces). Total = 32000 uF
parallel...
OR
One cap for each range? Which means 3 caps connect in parallel.
Which is the most effective?
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
