Airbag Light.
99frontierxe
Posted: December 16, 2002 at 2:47 PM / IP Logged
I have a 99 Nissan Frontier that I am doing a custom fiberglass console on.  I had to remove the passenger airbag control switch to accomodate the active x-over that I am installing.  Anyway, after plugging back in the switch, the airbag idiot light is blinking.  I tried removing the battery overnight, but the airbag light is still on!
Has anyone else experienced this problem, and what did you do to fix it? I just don't want to take it to the dealership to have the ECM Diagnosed... they want 85 bucks for that!  Thanks for your help in resolving this matter.
webguy
Copper - Posts: 89
Posted: December 17, 2002 at 5:31 PM / IP Logged
I know there is a way to reset the SRS system, but I am not sure. You might try posting your issue at http://www.infinitihelp.com/Nissan/Index.htm. They have a forum at http://www.infinitihelp.com/Forum.htm
Good Luck!
Clean tools = Clean work!
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
