2003 Chevy Silverado
metalmind1
Member - Posts: 23
Posted: December 29, 2002 at 9:11 PM / IP Logged
Well folks, i have a new truck and im lookin to put a system in it! i already have all my stuff, im just weary about goin into a new ride and cuttin wires and sh*t. anybody have experience with these trucks and/or places where i can get some reference info? any help would be appreciated
thanks
Platinum - Posts: 12,488
Posted: December 30, 2002 at 7:37 AM / IP Logged
Check to see if the door chime is going through the driver side speaker. If it is, you have a ODBII system in the vehicle . This means that the radio controls certain functions of the truck that is required and you have to retain it or get a harness that bypasses the OEM system.The Metra # vt-gmrc-01 allows you to install an aftermarket radio in a class II vehicle without having to use the 70-2003T and SP-2003 speaker. It has all the electronics and speaker in a small unit so you don't have to use the OEM radio.
http://metra.victorytechnologies.com/press_releases/innovations_archive_092402.asp#1
metalmind1
Member - Posts: 23
Posted: December 30, 2002 at 12:48 PM / IP Logged
sweet. now my other question,  is how the hell do i get door panels and dashs off? is there some trick to it?
Posted: December 30, 2002 at 1:06 PM / IP Logged
Good questions. Look for all srews and remove them. The door handle plate usually needs to be slid to the side and then pulled out. The whole door should be clipped in with the white panel plugs. You will need to unplug the harness from the door lock and window modules after you get the door panel unhooked from the door skin.
metalmind1
Member - Posts: 23
Posted: December 31, 2002 at 12:23 AM / IP Logged
cool, and do you know where i can get this crazy wiring harness? :D
Posted: January 01, 2003 at 10:37 AM / IP Logged
http://metra.victorytechnologies.com/contact_us/contact_us.asp
Click on the location that you are at and it will give you contact information to the closest metra dealer.
