command start CS2400
stanley_cups
Posted: February 08, 2003 at 9:32 PM / IP Logged
I am trying to install the Command Start CS2400 on my 1990 Nissan Maxima.  I can not find a wiring diagram for this model of Command Start.  Also, I am not sure how to deal with the factory alarm.
Platinum - Posts: 12,488
Posted: February 09, 2003 at 8:02 AM / IP Logged
Command Start CS2400/2500 Installation Diagram
Click the above link for the wiring diagram.
stanley_cups
Posted: February 09, 2003 at 8:47 AM / IP Logged
Thanks for the help!
How would you suggest I deal with the factory alarm?
Posted: February 09, 2003 at 9:10 AM / IP Logged
|FCTRY ALRM DISARM|lt.grn/blk/ sil dots|-  |anti-theft module
There is a wire that is a (-) prior to start taht you can use from the CS2400.Attach it to this wire.
stanley_cups
Posted: February 09, 2003 at 8:18 PM / IP Logged
New problem...I have the unit installed and when I press the start button, the car attempts to start by cuts of before turning over.  Any idea what I could be doing wrong?  I doubled checked all my wiring.
Posted: February 09, 2003 at 9:35 PM / IP Logged
Make sure that both starter's wires are connected ( Second Starter Relay Diagram ) and also, make sure that the tach signal is properly learned to the unit. Default setting for the unit is a 6 cylinder.
stanley_cups
Posted: February 09, 2003 at 10:24 PM / IP Logged
I did make sure both starter wires are connected and have used a relay as per the relay diagram.  How do I make the tach signal learn to the unit.  Maybe you are onto something as this starter was in my friends intrepid.  I have installed it to my Maxima.  Both are 6 cylinders however.
