2003 Sunfire cruise control
opj38
Member - Posts: 31
Posted: May 26, 2004 at 10:42 PM / IP Logged
hi I am Trying to install a cruise control in a sunfire and would like to know if the Vss wire is also located in the Obd11 test plug located under the dash or do i have to go to the PCM. If it is then which wire or what color is it.
Thanks in advance
Platinum - Posts: 12,488
Posted: May 27, 2004 at 9:22 AM / IP Logged
VSS Wire: LOCATION 12- BLUE CONNECTOR OF ECM POSITION 34
VSS Wire Color: GREEN / WHITE
VSS Pulse: 4000
VSS Tach Wire: LOCATION12- BLACK CONNECTOR OF THE ECM- ONLY WHITE WIRE
Tach Signal Wire Color: WHITE
Brake Switch Positive: ORANGE
Brake Switch Negative: WHITE
opj38
Member - Posts: 31
Posted: May 27, 2004 at 9:40 AM / IP Logged
Thank you for the quick response, but one little question, Where is the ECM located in this car , inside or in the engine compartment?
Posted: May 27, 2004 at 10:01 AM / IP Logged
The PCM is on the passenger side rear of the engine compartment
opj38
Member - Posts: 31
Posted: May 27, 2004 at 8:45 PM / IP Logged
one more. this is a electric servo , big and in the passenger side there is not enough room , so this is where to mount it . Also the cable is very long, can i mount the servo and cut the cable to length.
Posted: May 28, 2004 at 12:14 AM / IP Logged
Yes, you can cut the wire to length if necessary.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
