Tacoma brake light wire
akprodr
Posted: July 21, 2004 at 12:43 AM / IP Logged
I'm new to this car wiring stuff. I'm actually not wiring a cruise control but this is kinda similar. I'm wiring a trailer brake controller. I need to hook it up to the brake light switch. On my 2000 Tacoma, this is virtually inacessible. I see on the wiring charts that I want a GREEN / WHITE wire. Is this the ONLY GREEN / WHITE wire? If I tap into A GREEN / WHITE will it work?
Thanks,
Andy Tejral
Anchorage, AK
sparkie
Platinum - Posts: 2,061
Posted: July 21, 2004 at 8:07 PM / IP Logged
The GREEN / WHITE wire is the switched brake light wire. This wire will show 12 volts + when the brake pedal is depressed. Use a digital volt meter to test for the correct one. It is found at the brake switch above the brake pedal.   Unplug it to access the wire better to mske your connection.
sparky
akprodr
Posted: July 21, 2004 at 10:19 PM / IP Logged
Thanks, I found the wire easily enough. It was probably quite amusing if anyone was watching me: I had my feet up at the headrest and my head wedged under the pedals. That's the only way I could get to it.
Now, anybody know the best place to hook up reverse lights for this trailer?
sparkie
Posted: July 22, 2004 at 6:28 PM / IP Logged
Trace the wiring from the tailights and follow it to a place where you can make a safe and proper connection. In most pickup trucks the harness from the tail lights runs under the truck. You may want to find the area where it enters the inside of the truck or use some sort of weather packing to insure a good and durable connection right at the tail lights themselves. The reverse light wire should be reb/black (+) in the driver's kick panel.
sparky
akprodr
Posted: September 02, 2004 at 4:51 PM / IP Logged
<after a suitable amount of procrastination time has passed>
Would you happen to know if this wire goes to the engine compartment or does it end in the kick panel? (I've already run a wire from the back of the truck to the engine compartment.) Is there a fuse somewhere?
Andy
audiopro111
Copper - Posts: 160
Posted: November 03, 2004 at 7:59 PM / IP Logged
there's a green white at drivers kick panel for brak ewire just test to make sure
AudioPro111
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
