GM Throttle Adapter?
NowYaKnow
Gold - Posts: 1,217
Posted: January 12, 2003 at 8:39 PM / IP Logged
Hey..Lately I've run into a problem when installing cruises..It seems the plastic connector that snaps on most throttle bodies is just a little too big for certain GM throttle bodies..It seems to snap on like normal but then just falls off when it moves. I talked to some other guys and they said they just put a wire tie around the connector to help hold it on..I was looking for something a little more reliable..Anybody know if they make any adapters for these slightly smaller ones? Thanks for any info.
the12volt
Administrator - Posts: 3,959
Posted: February 02, 2003 at 12:16 PM / IP Logged
If the adapter is too small to hold it on place, thread a nut on the cable, then run it through a piece of cheese strap that you can screw near the opening on the bracket, then thread another nut on the cable to secure it in place.
