motorized amp rack
chaos420
Copper - Posts: 47
Posted: January 15, 2008 at 2:26 AM / IP Logged
Can anyone figure this out?  I want to build a motorized amp rack that rotates at an arc, but the problem i'm having figuring this out is keeping the amp horizontal while maintaining a pivot that it will need to move on the arc.  Balance is not really an option and every configuration i can come up with leaves the amp either spinning freely on the pivot, or fixed to it slaming the sides into the ground rather than easing the bottom onto it.  It might be simpler than it seems and i'm just overlooking it.  If anyone has an idea to get this to work, or even a completely different solution that gets the same results, please help.
motorized amp rack -- posted image.
dudehitt
Member - Posts: 17
Posted: January 15, 2008 at 4:42 PM / IP Logged
try 2 arms with their own centers and attachment to the amp rack.  That way the amp should stay horizontal.  The sets of arms would have to be offset so they don't hit each other, but I think it will work.  I can try to figure it out for real probably tomorrow, just let me know if you need it.
chaos420
Copper - Posts: 47
Posted: January 15, 2008 at 10:46 PM / IP Logged
Like this?
Yeah, it seems like that would work, and it's so simple.  I just had my mind set on one arm I didn't even think about it.  Thank you.
jmelton86
Gold - Posts: 1,228
Posted: January 16, 2008 at 4:04 AM / IP Logged
Build pics are a must in this forum! motorized amp rack -- posted image.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
dudehitt
Member - Posts: 17
Posted: January 16, 2008 at 9:07 AM / IP Logged
chaos420 wrote:
Like this?
yep, that's what I was thinking.  the simple stuff is sometimes hardest to see, especially when you've already got an idea.
bellsracer
Silver - Posts: 703
Posted: January 18, 2008 at 12:43 AM / IP Logged
Another option would be to use a geared arm and chain setup. This will eliminate the need to offset any arms or anything. A bit more complex a setup, but opens the arc up to a full 180 motion (or depending on how you build your rack, a full 360 motion)
There is more than one way to skin a cat! (But why would you want to?) §T-T§
Ganbatte ne!
chaos420
Copper - Posts: 47
Posted: January 19, 2008 at 6:13 PM / IP Logged
Ganbatte ne!
Could you explain?  I only need about 60 degrees of rotation.  I'll show you what i'm going for, using the stackable alpine pdx amps...
chaos420
Copper - Posts: 47
Posted: January 19, 2008 at 6:14 PM / IP Logged
Sorry about the crappy pics.
