91 Acura Sub-Box
KosmoSuVinitta
Posted: February 14, 2004 at 3:44 AM / IP Logged
Hey everyone, I've been reading the forum for a little while and trying to gather as much information as I can before I get to work on the box I am going to build for my car, and I still have a couple of questions, so here goes.
I'm going to need a box that will hold two 15" subs for the trunk of my 91 acura, and I'm curious what kind of matting would be best for this? I don't fully understand the differences between varying thickness' and what sort of hardener to use with it.
Also, if anyone knows what size box I should have for dual 15" AudioBahn Flame compression subs, it would be much helpful. I had a friend working on it for a while and he could never figure it out.
Any suggestions would be much appreciated.
If ignorance is bliss, is understanding pain?
S.I.Autosports
Copper - Posts: 98
Posted: February 15, 2004 at 4:49 AM / IP Logged
do you have any of the specs for the subs?  if you buy the resin it usually coms with hardener.  if not you can use MEKP.
