overlap fabric?
branvw
Copper - Posts: 90
Posted: February 28, 2005 at 10:09 AM / IP Logged
I have many years now doing this and i have never run into this problem, lucky for me it is my own car......I have made a small base, my sub will be mounted about 12" foward of where the base ends, due to the shape of the box (looks like a cannon from an old ship) the fabric has to overlap......Problem is i cant get it to do that and stay put, when i use spray glue it comes off.  The overlap is under the cannon and you will not see it without really looking but i would like it clean..... any one have ideas?
Platinum - Posts: 12,488
Posted: February 28, 2005 at 10:22 AM / IP Logged
Have you tried a two part epoxy adhesive? You can get it at most hardware stores. Here's what it looks like
branvw
Copper - Posts: 90
Posted: February 28, 2005 at 10:25 AM / IP Logged
nope, but i do use it alot so i can look into using that and fill the imperfections with rage,
1hot944
Copper - Posts: 46
Posted: February 28, 2005 at 9:19 PM / IP Logged
What about trying contact cement?? It's permanent and once those two pieces go together.... that's it!!
In a world full of copycats, it's great to be an original!
supradude
Silver - Posts: 915
Posted: March 02, 2005 at 11:05 AM / IP Logged
Have you tried 3M Super 77? I use it and it never loses hold. You can get it from Wal-Mart.
'85 Toy
branvw
Copper - Posts: 90
Posted: March 02, 2005 at 12:49 PM / IP Logged
yeah, I used it in this case, the prob is that it lets go when resin is applied...
spoontek
Member - Posts: 13
Posted: March 03, 2005 at 12:24 AM / IP Logged
How about LiquidNails at Home Depot?
Speed Kills!
Vancouver ricer!
If I marry a Surrey girl. Do I have to pay her for services rendered?
realitycheck
Silver - Posts: 751
Posted: March 03, 2005 at 8:02 AM / IP Logged
Hot glue gun,  it wont let go when resin is applied. Or staples,  staple it in place and then put resin on let it dry so it stays in place.  Then pull the staples out once its dry.
doc t
Copper - Posts: 169
Posted: March 03, 2005 at 11:49 AM / IP Logged
hot glue works great, 3m spray (just make sure it is dry) lastly staples or a combination of them (hot glue/staples or 3m/staples). I've never used epoxies so i cant say if there good or not.
All Bleeding stops.....eventually!
Master Asylum
Silver - Posts: 400
Posted: March 04, 2005 at 9:15 AM / IP Logged
Epoxies are incredible for their job. Not sure effectiveness in car, but well, they rule. Atleast IMO.
1998 Monte Carlo w/
Eclipse CD8454
2xRockford 5.25" Power 2-way T152C
2xRockford 6"x9" Punch 3-way FRC4369
1xMemphis 16-MCH1300 5-channel
2xKicker 12" L5 Solobaric-2 Ohm
