Mixing Bondo, Resin, and Acetone?
1sic88hatch
Member - Posts: 6
Posted: June 08, 2005 at 12:06 AM / IP Logged
I was wondering if mixing Bondo, Resin and acetone will give me a nice smooth finish on my FG inclosure. I've tried glazing putty but I just cant get rid of all the pits. If anybody could help me out that would be great. thanx
1 bad azz civic....Its Murda!!
j68rh
Copper - Posts: 147
Posted: June 08, 2005 at 4:03 AM / IP Logged
I just kept sandinging and filling with bondo until they are all gone.  its time consuming but it works.
abovestock
Copper - Posts: 247
Posted: June 08, 2005 at 4:21 AM / IP Logged
DON'T use bondo, it is 40 year old crap. Rage Gold and metal glaze work very well to fill and remove pin holes in prep for painting.
Lincolnman
Member - Posts: 20
Posted: June 09, 2005 at 10:44 PM / IP Logged
hatch,
Yeah I saw on here where some guy did a box for a beamer and used the mixture that you were talking about. He said that he was able to "paint" the mixture on with a brush. If I can find the post I will post a link. However he didn't specify the mixture ratios or which hardner he mixed in (bondo hardner or resin hardner). Any way it looked like a good experiment.
Nothing is impossible!
Lincolnman
Member - Posts: 20
Posted: June 09, 2005 at 10:48 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=57014&PN=1
HottAccord
Silver - Posts: 247
Posted: June 09, 2005 at 11:52 PM / IP Logged
I swear by Rage Gold, it sands like chalk on concrete!! Mixing Bondo, Resin, and Acetone? -- posted image.
Im a fiberglass whore!!
1sic88hatch
Member - Posts: 6
Posted: June 10, 2005 at 12:19 AM / IP Logged
Thanx lincolnman!   I think I might try that. I saw the post and it looked smooth. It would be killer if I could put it on with a paint gun. I need it smooth cuz Im painting the enclosure.
joebiv318
Member - Posts: 46
Posted: June 10, 2005 at 9:01 AM / IP Logged
Bondo is basically rein mixed with talcum power. Also Bondo hardener is basically the same hardener used in resin, with some talcum power. So to thin out bondo just add resin to your desired thinness and apply w/ a brush. I’m not sure about adding the acetone. I just use the resin.
Owner/ Custom Compact Performance
Treo,Cadence,ARC Audio
Critical Mass/Icon TV
Panasonic,Compustar,Scosche
hbk00
Copper - Posts: 64
Posted: June 10, 2005 at 3:47 PM / IP Logged
or try bondo glass work great and sands pretty decent too
go custom or go home!!
oonikfraleyoo
Gold - Posts: 1,069
Posted: June 10, 2005 at 8:00 PM / IP Logged
Why add resin? I can almost see thining the Bondo if you can't get Rage, but I don't understand the resin. Glazing putty is not for smoothing out an enclosure, just to fill tiny pinholes. I also doubt your gonna find anything that will spray on. You need RageMixing Bondo, Resin, and Acetone? -- posted image.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
