Flame polishing Plexi
Atl_monte
Copper - Posts: 90
Posted: August 20, 2005 at 10:34 PM / IP Logged
How do you go about flame polishing plexiglass?
abovestock
Copper - Posts: 247
Posted: August 21, 2005 at 3:14 AM / IP Logged
get the plexi edege as you want it and use a blow torch. Move quickly so that the plexi does not over heat and melt too much.
Atl_monte
Copper - Posts: 90
Posted: August 21, 2005 at 8:45 AM / IP Logged
don't I have to sand the edge first? if so with what grit?
realitycheck
Silver - Posts: 751
Posted: August 22, 2005 at 7:51 AM / IP Logged
Can someone please explain to me what flame polishing is?  I am about to be using some engraved plexi and I would just like to know thanks.
firstclassohio
Member - Posts: 37
Posted: August 22, 2005 at 9:18 AM / IP Logged
We always wetsand the edges of our plexi with 1500 grit  then 2000. then we hand polish with Novus.
under promise and overdeliver
customcarchris
Copper - Posts: 95
Posted: August 22, 2005 at 9:17 PM / IP Logged
If I am thinking what you are thinking, it is one hard task. The plexi I have has some scratches in it, but you can sand them out to 200 grit, but the plexi starts to fog. You can take an open flame a lightly and very quickly go over the top and take this fogging out, but if you are only ONE second too quick, you will put bubbles in the plexi. Same with power buffing, if you don't go long enough, you still have fog. If you go too long, you get a burn mark. Maybe someone has a better method of getting plexi clear again after taking the scratches out of it. I haven't found one yet, these other methods are too hard to not screw up with.
abovestock
Copper - Posts: 247
Posted: August 23, 2005 at 2:53 AM / IP Logged
to get it clear treat it like clear coat. Start out with a rough grit and work finer and finer untill you end up with 3500 grit and then polish. When an aircraft winshield gets a scratch in it this is what we do and it usually takes 6-18 hours to work out as long as it is not too deep and can be serviced.
