Steady Turn signal wire
sammy004
Member - Posts: 19
Posted: March 01, 2003 at 7:42 PM / IP Logged
Can someone please give me some in deapt info on getting a steady live wire from my turn signal. I found something in the misc. sec. under pulse to steady output from this site but I need more info on some of the stuff.
https://www.the12volt.com/relays/page5.asp#pts
Two_Cold
Copper - Posts: 91
Posted: March 01, 2003 at 9:00 PM / IP Logged
If you go as close to the turn signal switch as possible. Before the "flasher relay" the power should be constant. Look up your car on this website and see if there is a wiring chart with correct color.
sammy004
Member - Posts: 19
Posted: March 01, 2003 at 10:11 PM / IP Logged
I tried that I have a 97 chevy Z71 and there is no wire before the flasher like it use to be on the old cars it's all computer chiped and stuff
securinu
Silver - Posts: 772
Posted: March 02, 2003 at 8:26 AM / IP Logged
what are you trying to do maybe we can figure something out if you let us know what you are trying to do
sammy004
Member - Posts: 19
Posted: March 02, 2003 at 6:49 PM / IP Logged
I have a side marker from eurolight and it has 3 fuctions on it a stedy LED non-flash, Flashing LED, and side to side scanning mode. what I am tring to do is hook up the steady mode to my lights so when i turn my lights on they go on however when i turn the signal light on I want it to go in the scanning mode when signal is off its back to normal on I figured it all out and something on this site i found usefull as well i just dont know what a 10k fixed resist is or a 10k uf capacitor and how to det a diode in between 86 and 85 as seen on this page.
Friday, November 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
