new dome lights with new switch wiring
ajan246
Member - Posts: 22
Posted: February 14, 2010 at 9:52 PM / IP Logged
Ok guys here is what i got. I have a 97 nissan pickup. What i did was replace the single dome light with 4 cold cathodes. There are 3 wires going to the old dome light. RED / black, RED / green, and black. These wires are for the door pin switches that control the on/off/door function of the dome light. What I am trying to do is have the new dome lights come on when either of my door is open; be able to turn the lights off while either door is open, and be able to turn the lights on while the doors are closed. I did some testing and these are my results:
RED / green - 12v constant
RED / black - not sure (i know its negative though)
black - negative/ground
i have 12v between: RED / green and black
      RED / green and RED / black
but i can't figure out the wiring for my switch. I don't even know if what i want is possible with what i have. I'm just using a 3 prong switch its an automotive switch with an LED.
One of these.
new dome lights with new switch wiring -- posted image.
any help is appreciated! Thanks!
-ajan246
oldspark
Gold - Posts: 4,913
Posted: February 14, 2010 at 10:39 PM / IP Logged
Without looking wiring figs nor knowing your model etc, the RED / black is probably the door switch. I presume your exiting dome switch selects off, door, or on - the same as you want.
If so, no wiring changes are required.
If you want a remote "master on" switch, parallel the door or "on" switching.
For master off, you need to break the connection - probably power.
Most door switches are single-wire grounding, but can be 2-wire and either grounded or hot (+12V).
See also led triggered by dome light and on/off/on (page 2) that has the image below.
ajan246
Member - Posts: 22
Posted: February 15, 2010 at 12:22 AM / IP Logged
can anyone explain this diagram? I'm not sure what i'm looking at.
oldspark
Gold - Posts: 4,913
Posted: February 15, 2010 at 3:42 AM / IP Logged
The left side might be the same as your vehicle's wiring.
The RHS is the added LED or LEDs with resistor, and a 3-position switch for on, off and whatever the dome selector switch is (that's with the RHS switch as it wipes from right (3) to left (1)).
If instead you want on, off & door, then connect the leftmost (1) of the RHS switch to the door switch(es) - ie, middle terminal of the dome selector switch (assuming it has 3 positions - namely off, door & on).
97accord
Member - Posts: 17
Posted: April 18, 2010 at 3:29 AM / IP Logged
can anyone explain what the lighting rods is?
also where is that 12v zig zag attached to?
also did anyone oldspark way to wire the switch to the led's and dome?
Platinum - Posts: 13,725
Posted: April 18, 2010 at 6:53 AM / IP Logged
The lightning rods indicate that the things next to it are LEDs.  Light Emitting Diode.  The lightning bolts are the light coming from the devices.
The Zig Zag you are refering to is a resistor.  The resistor should be connected to a constant 12volt feed.
97accord
Member - Posts: 17
Posted: April 21, 2010 at 12:50 AM / IP Logged
has anybody used this method to turn their interior light like this...if you did does it work like this
Dome off +switch off = no light
Dome off + switch on = light
Dome on + switch OFF = light
97accord
Member - Posts: 17
Posted: April 21, 2010 at 1:56 AM / IP Logged
also is oldspark setup can only be use with a 3 way switch....or can i use a 2 way switch
97accord
Member - Posts: 17
Posted: April 21, 2010 at 1:59 AM / IP Logged
does anyone know how high of a resistor i need to get
oldspark
Gold - Posts: 4,913
Posted: April 21, 2010 at 3:07 AM / IP Logged
If using my diagram, it'll be:
Dome off + switch off = no dome nor LED
Dome off + switch on = LED
Dome on + switch OFF = dome
Dome on + switch on = dome & LED.
Dome = door etc - as above where ON = door open (switch closed to ground).
This should be explained in the link - IE - assume the left side is the normal Dome wiring.
The extra RHS 3-position switch is for LEDs to (1) light with dome; (2) be off; (3) be on.
Use a 2-way switch if one of the above positions is not necessary.
If the LEDs are ~3-3.4V, you might not need a resistor.
Assuming you have the 4 LEDs in series, and Vf is the LED voltage drop at current I (eg, 1.7V or 3.4V @ 20mA = 0.02A), and VS is the supply voltage, then the resistor size required is (from V=IR =>R=V/I):
R (Ohms) = (VS - 4xVf)/I
EG assume worst case: R = (15 - 4x3.4)/0.02
= (15 - 13.6)/0.02
= 1.4 / 0.02
= 70 Ohm.
Hence use nearest preferred value of 68 Ohms or 82 Ohms.
The resistor's power rating should be I x I x R
EG = .02 x .02 x 82 = 0.03W, hence a 1/2W (recommended size) is ample. Although 1/8W = 0.125W is also ample, they are physically small etc.
Page of 4
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
