would this be a problem? leds, 08 tundra
jaykiller1
Member - Posts: 6
Posted: September 28, 2011 at 2:03 AM / IP Logged
Hello all,
First I am JD. I have been a lurker on here for a lil while and have learned a good bit. I am preparing to install some leds on my truck but I just wanna get some opinions before I jump on this.
Setup:
2008 Tundra SR5 Double Cab
These leds:
The LEDs that I am wanting to use.
I want to put two on each running boards. One at each end. Also I choose the amber color.
I would like to do this so that they correspond with the interior lights. The 08 Toyota has dimming interior lights and I would like the leds to match that behavior.
Thanks,
JD
Until you sign a blank check to your government in payment in the form of your life. You can not really say anything to upset me!! Have a good day!
jaykiller1
Member - Posts: 6
Posted: September 28, 2011 at 2:05 AM / IP Logged
Here is the address in case the link does not work.
http://www./itm/190578079828?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_4948wt_1014
Thanks,
JD
oldspark
Gold - Posts: 4,913
Posted: September 28, 2011 at 6:10 AM / IP Logged
Incomplete URL.
The LEDs won't dim with the interior lights unless it's a PWM dimmer, and most are analog (they simply drop the current).
Platinum - Posts: 13,724
Posted: September 28, 2011 at 8:07 AM / IP Logged
They will dim, just not in a linear fashion. It would be like the fuel gauge on an old 280ZX, the 1/8 tank to empty gauge will be at full tilt till it reaches 1/8 tank of fuel, then it begins to go down as well. The LEDs will not begin dimming until the Incandescent lamp is almost all the way out.
Spark, how are you going to reduce the current without reducing the voltage??
jaykiller1
Member - Posts: 6
Posted: September 28, 2011 at 4:28 PM / IP Logged
Thanks for the quick replies. Ok so I figured as much. Had to ask though. Another question for y'all in relation to this job. Where would y'all recommend wiring these to?
JD
oldspark
Gold - Posts: 4,913
Posted: September 28, 2011 at 5:12 PM / IP Logged
PWM - LEDs do not dim linearly with resistive drops whereas PWM is essentially proportional dimming and matches most lamps.
Try a LED on a normal dimmer - it will barely dim until it eventually drops off radically.
jaykiller1
Member - Posts: 6
Posted: September 28, 2011 at 5:28 PM / IP Logged
Here is the link again. Hope it works.
https://item.mobileweb./viewitem?itemId=190578079828&index=2&nav=WON&nid=56765977853&trxId=587780716009
oldspark
Gold - Posts: 4,913
Posted: September 28, 2011 at 8:20 PM / IP Logged
No - it lacks the "com", but even that isn't enough....
But in essence, LEDs is LEDs. If they are 12V, they can be powered in parallel to any 12V item.
And typically being lower in current (eg, 20mA per series string compared to 250mA for a 12V/3W bulb) they have negligible load effect. (EG - they are several tens ot hundreds of Ohms and thence can be placed across speakers.)
But they will not dim like bulbs, nor dim proportional to voltage (nor current?).
jaykiller1
Member - Posts: 6
Posted: September 28, 2011 at 10:51 PM / IP Logged
Well let me try it like this then:
would this be a problem? leds, 08 tundra -- posted image.
Uploaded with ImageShack.us
Total 20 LED Lights
5 x Ultra Bright 4 LED Courtesy Lights Pod w/ Chrome case
For Motorcycle, Automobile, Boat, and more
Available in following colors to choose from:
Blue, Red, Green, UV, Amber (Orange), White (Advise Pictures below)
This DIY 4-LED spreader comes with 4 LED bulbs diagonally mounted in a ellipse shape enclosure. They come with 3 foot long, 22 gauge and 2-wire black sheathed lead that can be widely used in any 12 volt application for motorcycles, boat, home decoration, auto modding and more.
________________________________________
Features:
Motorcycle / Car 4LED spreader comes with 4 LED bulbs mounted in a
Width 3/4" , Length 1 1/2", Height 3/8" enclosure.
•     They come with 3 foot long, 22 gauge wire
•      Easy 2-wire Positive/ Negative incased w/ a black sheathed jacket
•     Used for any 12 volt application (motorcycle, car or suv auto modding).
Installation Tips:
Use on Motorcycles, ATV's, Snowmobiles, Golf Carts, Go-Karts, Computers, Cars, Trucks, SUV’s, RV's, Motor Homes or anything you can think of.
A unique and smarter alternative to traditional neon tubes!!!
Benefits of using 12Volt LED’s vs Neon:
LED’s (Light Emitting Diodes) don't get hot like regular incandescent lamps or Neon, and only also use approx 2ma of Power.
•     LED LIGHTS use so little power they can be used in computers.
•      Hyper LED technology., ISO 9001 - These are the brightest leds on the market.
•     Make sure your leds are HYPER Bright.
•     Leds typically last 100,000 hrs as opposed to neons at 30,000 hrs at best.
•     Leds are not prone to weather, and are virtually indestructible.
• Colors: Blue, Red, Green, Orange, UV, Amber, White ( Please note the color of choice along with payment for faster delivery)
Specifications:
• 4 Super Bright LED Bulbs.
• 22” Wire with 12v 4 pin male and female connectors
• 200,000 hour life (22 years)
• Voltage range 12-14 volts D.C.
• Draw: less than 26mA @ 12 volts!
• Dimensions (WxLxH): 1 1/2" x 3/8" x 3/4".
FAQ:
How do I mount these?
The 4LED pods can be mounted with screws (one on each side) or use glue, epoxy, tape, velcro etc. Twist ties can work well for motorcycles.
Is it water proof?
These are water resistant. They can be submerged in water, however we do not recommend for long term use.
What is it made from?
Made from plastic with chrome layer.
How much current does each take?
No more than 50 mA each unit. Don't worry about power consumption, these are very efficient.
jaykiller1
Member - Posts: 6
Posted: September 28, 2011 at 11:04 PM / IP Logged
spark something you said got me wondering..about being paralleled. So if I ran one pos and one neg all the way around the underchasis I should be able to tie into each wire and all the way around.
___________________________________{-}
____________|___________________|__{+}
      [LED]              \[LED]
Sorry if this looks a bit silly but it was the best
I could do.
Still looking for suggestions as to where to tie in to for power.
JD
