found a burnt wire to tail light
HAlf_BlkandAsn
Posted: August 01, 2004 at 3:29 PM / IP Logged
i found i RED / black burnt wire in my left taillight assemly. i believe this is the wire for my turn signals which are not workin...im not sure if the same problem has occured in the right taillight (its raining, ill check it when it stops) but i was wondering how i would be able to replace this wire? and also, should i check the entire wire (fom the taillight to my steering column where the switch is located) before i just change the wire that is visibly burned?
thank you
chris
HAlf_BlkandAsn
Posted: August 01, 2004 at 4:00 PM / IP Logged
ok, i just checked, the wires for the right taillight are all fine...i looked and found out the RED / black wire goes to my brake lights...the brake lights work when the brakes are applied but do stay on in their dim state when the parking lights or headlights are on (what is going on???)...if this wire is not my turn signal wire...what could be the cause of my turn signals not working?
chris
Maxst
Silver - Posts: 866
Posted: August 02, 2004 at 9:06 PM / IP Logged
if neither side works. check fuse.
What car is this?
Take off switch and look to see if the connections are damaged from years of use and/or are dirty.  Look for broken wires too.
I need quality equipment, feel free to donate.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
