undercar neon connected to dome light
ntwin98
Posted: July 05, 2005 at 10:30 AM / IP Logged
Hi everyone. i'm wanting to connect two undercar neons to my doom light or trigger so they come on when i open my doors. does anyone have a clean easy way to do this. i have a 94 accord ex
maglin
Copper - Posts: 206
Posted: July 07, 2005 at 10:02 PM / IP Logged
run the wire that sends 12 volts up to your lamp to a relay, use this relay to switch on the power to your underbody lamps. don't forget to fuse everything.
~~Vinn
ntwin98
Posted: July 08, 2005 at 10:44 PM / IP Logged
thanks
Dilligaf
Member - Posts: 28
Posted: July 11, 2005 at 11:00 AM / IP Logged
~~Vinn
thats exactly what i did with my 03 ion. Looks awesome. when you open the doors, or use the keyless entry to unlock the doors, they come on. when the dome light fades out, or you use the remote to lock the doors, they fade out. And when the alarm goes off, they flash with the headlights. You'll love it.
Phenz
Copper - Posts: 48
Posted: July 12, 2005 at 11:23 PM / IP Logged
Hi. How would you set up the relay to do this? What kind of relay should I buy, and how would the connections be?
I appreciate your help!
