2006 dodge ram headlight wiring
rfd614
Member - Posts: 6
Posted: January 23, 2007 at 11:37 AM / IP Logged
Does anyone know what the headlight wiring is for the dodge ram 2006? I am needing to hook up a highbeam headlight flasher also know as a wig-wag to this truck. I am not sure what wires to use from the factory headlights.
hollywood,rfd614
KarTuneMan
Platinum - Posts: 7,056
Posted: February 04, 2007 at 9:12 AM / IP Logged
If it's an emergancy vehicle....add you own lights, don't try and tag the factory harness. They are all controlled thru diff. resistance values.  The shop I work at does it this way...as to NOT interfear with OE opperation.
