2007 dodge ram stereo
nightowl2
Copper - Posts: 91
Posted: January 07, 2008 at 10:09 AM / IP Logged
I've posted before asking about the wiring but I've got a new problem. I want to install the aftermarket stereo that I had in my 2005. I know it is not just a simple swap. I have to get all new adaptors. My biggest concern is the interface that costs $70 or more! Whay couldn't I just hard wire the stereo using a relay for the turn on? I could just find a wire that has 12v when the key is in the on position and use that wire for the trigger. I'm not worried about having the radio on after I remove the key from the ignition. I never use that feature for anything other than as a "look what I can do" showing it to friends anyway.
dwarren
Posted: January 07, 2008 at 12:13 PM / IP Logged
I don't use those can-bus adaptors either, the cig lighter or accessory cig lighters on the dash usually provide me with a switched source for the deck. Don't waste the money, besides the cig lighters, I am sure there is an accessory under the dash, you wont even have to use a relay.
tedmond
Gold - Posts: 4,610
Posted: January 07, 2008 at 4:14 PM / IP Logged
I guess this is what you are looking for.
Audio/Mobile Video
WIRECOLORPOLARITYLOCATION
Battery GRAY/RED (+) RADIO HARNESS
  OR RED
Accesory LOOK AT NOTE ON THE BOTTOM OF PAGE THAT I WROTE !
Ground BLACK/ DARK GREEN (-) RADIO HARNESS
  OR BLACK
Illumination ORANGE / DARK BLUE (+) RADIO HARNESS
Amp Turn On DARK GREEN/ RED (+) RADIO HARNESS
LF Speaker (+) DARK GREEN
LF Speaker (-) BROWN / RED
RF Speaker (+) VIOLET
RF Speaker (-) DARK BLUE/RED
LR Speaker (+) BROWN / YELLOW
LR Speaker (-) BROWN / LIGHT BLUE
RR Speaker (+) DARK BLUE/WHITE
RR Speaker (-) DARK BLUE/ORANGE
Accessory 1 VIOLET/BROWN (-) IGNITION HARNESS
The acc switched is a negative @ the ignition harness. Removing the steering wheel collum will give you access to the ACC Wire or 12v switched. Connect a relay like so to change polarity of the wire.
Relay Pin Setup
85 - Constant 12v
86 - Ground from acc wire VIOLET/BROWN @ ignition harness
70 - High current 12v
30 - To 12v switched wire on deck.
gms81
Member - Posts: 47
Posted: January 07, 2008 at 4:25 PM / IP Logged
I just installed a stereo in my '06 and I used the cig lighter, works fine.
big sexy lac
Copper - Posts: 153
Posted: January 07, 2008 at 6:01 PM / IP Logged
So is there a alt. Wire harness other than the can-bus or are you saying you chop of the factory harness? And wire it up that way
well?
tedmond
Gold - Posts: 4,610
Posted: January 07, 2008 at 6:38 PM / IP Logged
you can use the factory harness. DONT CHOP grab a harness. THe only thing that is DATA is the Accessory wire or 12v switched from the Factory radio harness.
big sexy lac
Copper - Posts: 153
Posted: January 07, 2008 at 7:37 PM / IP Logged
Aah kinda like a gm that has bose you can still use the american intn'l harness 344 you just have to use the remote wire to turn on the fact. Amp.
But in this case you gotta run a 12v switched, is this common on newer dodge/chrysler cars?
Learn something new everyday!
well?
