speaker wattage drops
michael.laroya
Member - Posts: 21
Posted: January 16, 2008 at 3:40 PM / IP Logged
I heard that if you run a sub at a lower ohm it 's wattage handeling drops is this true?
bighead
haemphyst
Platinum - Posts: 5,059
Posted: January 16, 2008 at 3:58 PM / IP Logged
No, but the amplifier (to a point) will put out more power.
Also, it is impossible to "run a sub at a lower ohm". A subwoofer is rated as a load, specified IN ohms, and cannot be changed. Multi-voicecoil drivers can be configured to present different loads TO or FOR an amplifier, but the woofer impedance does not change.
aznboi3644
Gold - Posts: 2,600
Posted: January 16, 2008 at 9:54 PM / IP Logged
I'm curious to know what genius you heard this from.
michael.laroya
Member - Posts: 21
Posted: January 17, 2008 at 9:24 AM / IP Logged
i seen it on onother fourm but i can't remember which forum. I also never heard of that so just wanted to confirm. Thanks
bighead
