reverse mounting subwoofer wiring
knockn4life
Member - Posts: 9
Posted: May 23, 2008 at 10:14 PM / IP Logged
i have a 15" rockford hx2 that i just reverse mounted on a shallower box that it had and i lost sum bass. i connected the + and - reverse but im not sure if i have to switch the 0* or 180* phase on my headunit or amp. oh and i have the sub wired at 1 ohm and i dont know if i need to re arrange the wiring on this too or just leave it how it is. please help!!!!
2001 dakota r/t 1 15"RF HX2
1 1000BD power amp 1 1 farad cap 4 channel amp
DYohn
Moderator - Posts: 10,741
Posted: May 23, 2008 at 10:17 PM / IP Logged
If you only have one speaker there is no need to wire it in reverse polarity.  What do you mean you "lost sum bass"?
knockn4life
Member - Posts: 9
Posted: May 23, 2008 at 10:29 PM / IP Logged
its doesnt hit as hard as it did in the sealed box that i had it in. it gets distorted when i turn it up at the volume that i used to beable to listen to it at.
stevdart
Platinum - Posts: 5,816
Posted: May 24, 2008 at 6:22 AM / IP Logged
You downsized the enclosure airspace?  So you're comparing output as it is now to what it was in a larger box.
Sunday, November 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
