12v regulator?
isoking
Member - Posts: 8
Posted: July 27, 2008 at 6:52 PM / IP Logged
Hi, i have a mini pc that uses direct 12v / 5A
I want to get some sort of regulator to stop any power spikes in the power from damaging it. I have looked at alot of powersupplies but none go upto 5A.
Anyone know a schematic to make one. thanks in advance
haemphyst
Platinum - Posts: 5,059
Posted: July 27, 2008 at 7:50 PM / IP Logged
You can parallel 7912 positive voltage regulators... as many as you need! 1A with heatsinking is perfectly within the realm of safety for those devices.
A three-terminal device; ground, in, and out. REDICULOUSLY easy to implement. Seventy-nine cents each...
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
