speed pulse generator on 07 ford fusion
johnsanz
Posted: September 30, 2008 at 10:06 AM / IP Logged
I have a Pioneer AVIC-D3 Navigation/DVD unit, I have everything setup (Bluetooth/XM Radio/Amp) and ready to mount it on my 07 Ford Fusion. The pink wire coming out of the power cord is for the Speed Pulse Generator wire.. apparently this wire is very important for the navigation system, it can also be replaced by a NDPG1 (I believe) which is another after factory speed pulse generator.
So, where can I locate this wire? what color is it?
I found in some other forum that it is a light GREEN / WHITE wire on the back of the radio, but on the AVIC-D3 Installation Guide says this wire is coming from the computer.. so I am kind of confused.
Any ideas where is this wire exactly located and color? Please, will be very much appreciated!
-Johnsanz
All I know is that I Know Nothing
KarTuneMan
Platinum - Posts: 7,056
Posted: September 30, 2008 at 11:44 AM / IP Logged
VSS is BROWN / white @ the pcm next to the battery. Pin 56
johnsanz
Posted: September 30, 2008 at 12:10 PM / IP Logged
WOW!! That was quick!
Thank you very much! I'll keep you posted! thanks again!
-Johnsanz
basstoy
Member - Posts: 6
Posted: January 20, 2009 at 7:35 PM / IP Logged
how do you read the pin layout?? I need that wire too thanks!
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
