need info, orion xtreme xtr 100 amplifier
relfecting
Posted: March 11, 2009 at 2:31 PM / IP Logged
I have an Orion Xtreme XTR 100 sitting here. I have done a ton of research and the most I could find is that it "may" be the same as the NT 100 meaning its a 1000w x1 @ 1 ohm. Any info would be help full.
Also I'm looking for a balanced input converter and the speaker wire tail plug. If any one could point me in a direction to locate something I would be greatful.
lspker
Silver - Posts: 503
Posted: March 11, 2009 at 9:35 PM / IP Logged
Orion XTR were 4 ohm stable in mono, 2 ohm in stereo.  The NT was a "special"
audiocableguy
Copper - Posts: 630
Posted: March 12, 2009 at 2:49 PM / IP Logged
Are you looking for the 5pin DIN input or the Tm-3 small balanced connectors?
relfecting
Posted: March 13, 2009 at 11:21 AM / IP Logged
I'm looking for anything that will allow RCA input to be converted for this amp. So a din converter or a mini xlr line driver from orion..
Also I did a ton of digging around and found that these are the exact same amps as the NT series. I was also told by our Orion rep in this area that the XTR was produced first. Then they changed to the NT but nothing other then color was changed. I'm looking for internal pics now to confirm. I seen the xtr 200 and NT 200 and they have difference what so ever.
audiocableguy
Copper - Posts: 630
Posted: March 13, 2009 at 12:42 PM / IP Logged
You can use any PPI, Special Edition or Orion RCA to Din. They are both wired the same. Unbalanced. You can make your own easily. The speaker connector should be the standard Orion 9 pin Molex.
