what is making my grounds melt
the_one369
Copper - Posts: 80
Posted: March 26, 2009 at 10:54 PM / IP Logged
i smelled smoke then amps turned off and this is what i found. i tried to upload a pic but can't seem to figure it out. I have 2 ground cables that come together at my grounding point. Im just wondering what went wrong with my grounds. The cables themselfs melted a little bit and that is what caused my fuse to pop im just thankful that my fuse popped and everything is still in working condititon. any ideas why my grounds melted?
speakermakers
Copper - Posts: 231
Posted: March 27, 2009 at 12:47 AM / IP Logged
Resistance in the connection. The crimp and or the contact to the chassis of your vehicle has excessive resistance. Its really just that simple.
Platinum - Posts: 13,726
Posted: March 27, 2009 at 4:50 AM / IP Logged
As stated above, resistance = heat. It was either a bad connection or you have too small of a ground wire. Do you have a 4 Ga. power wire and an 8 Ga. ground wire?
aznboi3644
Gold - Posts: 2,600
Posted: March 27, 2009 at 8:51 AM / IP Logged
bad ground...thats it.
Custom Enclosure Design
the_one369
Copper - Posts: 80
Posted: March 27, 2009 at 10:47 AM / IP Logged
Thats what i figured the wire sizes are the same coming in as going out. Well time to rip everything out and redo it. I was looking for a reason anywaywhat is making my grounds melt -- posted image.
