2200 rms
youngiin
Posted: June 06, 2009 at 11:22 PM / IP Logged
what would be needed for a 2200 rms system?
icearrow6
Copper - Posts: 497
Posted: June 06, 2009 at 11:48 PM / IP Logged
Money first of all.
yimke
Copper - Posts: 417
Posted: July 01, 2009 at 7:01 PM / IP Logged
Upgrade the big 3, new alternator, probably a second battery, and more than likely a 2 farad capacitor. 0 guage power/ground cables, dual twisted RCA's, and a decent head unit to push voltage for that power. That is all recommended of course.
the12volt
Administrator - Posts: 3,959
Posted: July 02, 2009 at 10:51 PM / IP Logged
Topic moved to the car audio forum.
2200 rms -- posted image. the12volt • Support the12volt.com
glass22
Copper - Posts: 95
Posted: July 02, 2009 at 10:56 PM / IP Logged
icearrow6 wrote:
Money first of all.
That is funny because it is true.  There is more than just installing it.  But to begin you need an amp or combination of amps to get the 2200 RMS.
haemphyst
Platinum - Posts: 5,059
Posted: July 02, 2009 at 11:08 PM / IP Logged
Forget the cap... until you have an adequate power supply, it will only hinder, and if you have an adequate power supply, you don't need the "band-aid on the bullet wound", as there won't be any bullet wound, as it were...
ianarian
Copper - Posts: 516
Posted: July 02, 2009 at 11:22 PM / IP Logged
The complete renovation of the automobile into a rolling acoustic sound room. Hows about 1000$$ minimum in wire and soundproofing before 1 electronic component is purchased.
This is what I do for FUN!
