clarion shows amp ground
mysticshattaz
Posted: June 14, 2009 at 3:14 AM / IP Logged
i have a 2000 Nissan Altima
i installed a Clarion dxz385usb cd receiver and it worked great. but today it showed a message saying "AMP ground" what does that mean? n how can i fix this issue.
clarion shows amp ground -- posted image.
Azhar
Platinum - Posts: 13,725
Posted: June 14, 2009 at 6:49 AM / IP Logged
Check for grounded speaker wires.  (Of the speaker wires connected to the radio.  Not of an outboard amplifier)  Did you recently change any of your speakers?  If so make sure the terminals of those speakers are not touching metal.   Disconnect all speakers from radio and connect them back one speaker at a time.  Connect one, turn the radio on and see if the message is there.  Keep connecting speakers and turning deck on until the message reappears.  Then you will know which speaker wire is the problem.
If you have an ohm meter and would rather use that, simply unplug the harness from the back of the radio and check each wire for a short to ground.
mysticshattaz
Posted: June 14, 2009 at 2:30 PM / IP Logged
thanks it worked!
my trunk spring was touching the speaker harness so it shorted it out :x
but thank u again =)
Azhar
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
