clipping w/no gain?
thatfloorguy
Copper - Posts: 95
Posted: July 06, 2009 at 9:51 PM / IP Logged
Is it possible to clip my sub amp w/no gain adjustments? I turned up the bass boost on the amp all the way up, left the gain on the lowest setting I have been adjusting the bass w/the wired remote included with the amp and bass boost and sub volume settings on the HU. Is this safe for my sub and/or amp or is setting the gain an absolute? I cannot tell if it is distorting or not. Do I get a test tone cd, and if so what Db and Hz is recommended? Do I run it with just my sub amp on? Do I need a different one to set my main amp?
_______________________________
deh4900ib
zx350.4  (rear=6x9 and 5.25)(front+6.5 and tweeters) no X-overs
zx750.1(Lz15 wired to 2 Ohm)
4.75 net 65 sq"port tuned to 40 hz
entire rear dampened(dynamat extreme)
thatfloorguy
Copper - Posts: 95
Posted: July 06, 2009 at 9:53 PM / IP Logged
"96 cavalier"
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
