new 2009 nissan versa
dp85iroc
Member - Posts: 40
Posted: August 26, 2009 at 3:45 PM / IP Logged
so just got the new versa at a great price but it is a base model....and when i say base model i mean very base...
it has no stereo in it at all i was just wondering if anyone could help me out with this...i cant even get the filler plate, that is in the place of where the stereo would be, off so any advice would be helpful
thanks
hmmm...thinking is always good...but question are better
custombass
Copper - Posts: 54
Posted: August 27, 2009 at 1:33 AM / IP Logged
If you feel confident with cutting the plate out, that is one solution. Just ensure that there is enough room for a unit to fit inside the console. There should be ample space where an upgraded model's HU would be. Good luck!
wolfox
Member - Posts: 49
Posted: August 27, 2009 at 1:51 AM / IP Logged
How far are you taking your stereo upgrade/install? Pairing up sensitive fly-by-wire throttle and vehicle body modules; then piling a sensitive CVT gearbox (belt box?) imposes strict limits on how much you can load the alternator.
I do not know the specifics on the alternator output on that car, but I bet that the margins are slim on the bone stock entry level package. Shop and install carefully! You may inadvertently shorten the lifespan on a very expensive Xtronic transmission. (I keep an '03 Murano alive against it's will and barely survived an alternator recall and a weak battery replacement that made the gearbox act very strange until repaired)
Life is too short to build slow computers or weak audio!
wolfox
Member - Posts: 49
Posted: August 27, 2009 at 2:02 AM / IP Logged
just answered my own question with a google search:
Nissan Versa '09 Vehicle Specifications
It lists both the 1.6 and 1.8 Liter engine as having a 110 amp (2KW) alternator. Figuring in that it may have a pair of heated O2 sensors, acessory, light, and A/C loads, a deccently powered radio and an efficient 500 watt subwoofere amp can live peacefully if not pushed *too* hard, in my not-so-educated opinion. Pleases let us know if you succeed and what you ultimately decide to do - I am curious. I have a few friend looking at this car and also asking me about a system install aftermarket style.
dp85iroc
Member - Posts: 40
Posted: August 27, 2009 at 6:27 AM / IP Logged
well i do not kno if i would feel comfortasble cutting into my new car i mean it only has 200 miles on it and i'm actually not looking to go very far with this i may add subs later but for now i just want tunes
i'll try and post a picture of it later today so you guys can check it out
Platinum - Posts: 13,726
Posted: August 27, 2009 at 6:38 AM / IP Logged
http://documents.victorytechnologies.com//documents/product/8573.pdf
joch1314
Copper - Posts: 301
Posted: August 27, 2009 at 12:54 PM / IP Logged
Easy as pie with the right parts....isn't that right idiot.  that, a harness and antenna adapter should be all you need....hopefully it's wired for a radio.
...half of the truth can be worse than a lie. <----Roger Russell said that..
dp85iroc
Member - Posts: 40
Posted: August 27, 2009 at 3:05 PM / IP Logged
thank you so much!!! worked out great
joch1314
Copper - Posts: 301
Posted: August 27, 2009 at 5:45 PM / IP Logged
Another happy camper courtesy of the12Volt.com.
wolfox
Member - Posts: 49
Posted: August 27, 2009 at 7:17 PM / IP Logged
If I can be a bother, please post photos of the finished work? And thanks to I am an idiot for the PDF link - it was invaluable. :D
