amp power
nokie1
Member - Posts: 20
Posted: September 23, 2009 at 1:33 PM / IP Logged
my amp isnt getting power from the battery. i took the battery to get checked and its good. i put a test light on the wire coming from the battery to the amp  and got no power,used a new wire and still got no power from the battery. amp is good. now what?
shatteredk
Member - Posts: 11
Posted: September 23, 2009 at 2:14 PM / IP Logged
Check the fuse.
Make sure the connection between the battery terminal and the wire is actually good connection?
xtremej
Gold - Posts: 1,440
Posted: September 23, 2009 at 4:46 PM / IP Logged
Judging by your post, I would make an appointment to have it checked by a profesional.
haemphyst
Platinum - Posts: 5,059
Posted: September 23, 2009 at 5:05 PM / IP Logged
shatteredk wrote:
Check the fuse.
You DID install a fuse no more than 18" from the battery, didn't you? I have to ask, as you didn't mention it at all...
nokie1
Member - Posts: 20
Posted: September 23, 2009 at 5:59 PM / IP Logged
haemphyst wrote:
shatteredk wrote:
Check the fuse.
yes,would my voltage regulator have anything to do with it?(its an older car) it was working fine then it just stopped a few months later.
Platinum - Posts: 13,725
Posted: September 23, 2009 at 8:28 PM / IP Logged
Does the amp ever turn on?  If it comes on when the engine is not running, but does not stay on when you start the engine, then yes your voltage regulator could be a problem.  If the amp has never came on, the regulator is not your problem.
nokie1
Member - Posts: 20
Posted: September 23, 2009 at 8:52 PM / IP Logged
thanks for the help i found the problem(i should kick my own a@#) now my speakers are bumping when i turn the volume to one. btw i forgot i added a piece to my power wire to make it longer and where they connected had burned so thats why i wasnt getting poweramp power -- posted image.
