headunit memory problem
matthew perkins
Member - Posts: 13
Posted: November 22, 2009 at 9:19 AM / IP Logged
I have a sony CDX-RA650 head unit i have just replaced the ISO adapter for a new one, in a new car. The only way i could get my head unit to remember memory on my old ISO adapter was to connect the red wire with the yellow wire, however im unsure if this is the best way to tackle the problem?? shall i go ahead and connect the red wire to the yellow wire with the new ISO adapter? or is there a better way so that my head unit will remember presets when i turn off the ignition and back on???
Mpice
j.reed
Copper - Posts: 716
Posted: November 22, 2009 at 1:45 PM / IP Logged
You need to hook the YELLOW wire to a constant 12v positive wire. It is your memory wire. The RED wire is your switched power. Put it to a ignition/key positive wire.
If we knew what vehicle. It would be much easier to tell you the color codes and placement of these wire for you.
headunit memory problem -- posted image.
matthew perkins
Member - Posts: 13
Posted: November 22, 2009 at 2:05 PM / IP Logged
thanks for the reply, Its a seat ibiza 1997, the ISO adapter fits fine, i dont understand why the constant 12v wire should not be connected properly? but yeah think your right ile try it.
Mpice
j.reed
Copper - Posts: 716
Posted: November 22, 2009 at 3:10 PM / IP Logged
http://www.seatcupra.net/forums/showthread.php?t=107740&highlight=stereo+mk2+ibiza
Found a wire diagram. Looks like the GREEN/ blue wire is your ignition/key hot. That would go to your red wire from the radio. The red wire from the vehical is your constant and would be hooked to your yellow wire from the radio. I would check these with a voltmeter to ensure these are correct. Brown from the vehicle is you ground.
Monday, November 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
