crossovers
pcana11
Copper - Posts: 116
Posted: January 18, 2010 at 8:32 PM / IP Logged
what are crossovers. passive/active and what do they do? sorry for the beginner question
haemphyst
Platinum - Posts: 5,059
Posted: January 18, 2010 at 9:46 PM / IP Logged
They divide the entire audio band into smaller bands. A passive one goes between amplifier and speaker, and an active one goes between signal source and amplifier.
pcana11
Copper - Posts: 116
Posted: January 19, 2010 at 3:55 PM / IP Logged
alright, what would be the benifits? also price range for a good one?
DYohn
Platinum - Posts: 10,741
Posted: January 19, 2010 at 4:07 PM / IP Logged
A crossover is the heart of any loudspeaker system.  Any system you buy will have an appropriate crossover included or built in, unless you are building it yourself.  Most amplifiers also have active crossovers built in, called low pass filters and high pass filters.  You use both of these (passive and active) to send the proper frequency bands to the proper speakers.
What is it you're trying to do?  If you are purchasing your main speakers from an established brand name, you do not need to purchase any additional crossovers.  If you are building your own set or if you are trying to biamp a set of components, then you need to buy or build them.  I assume from your question that this is not what you are doing, correct?  If you are not trying to DIY your mains then you do not need an additional crossover.
pcana11
Copper - Posts: 116
Posted: January 19, 2010 at 6:01 PM / IP Logged
no, i was just wondering. never was sure about them. my amp i know has one built in. thanks for the info, that was exactly what i was looking for
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
