wiring options for 4 12 dvc's?
jiggad69
Posted: February 18, 2010 at 9:59 PM / IP Logged
Hi there! I have 4 12" Audibahn dvc subs. Im connecting them to an old school Soundstream tarantula 1600/2 amp. Problem is...this amp will only go down to a 4ohm load in mono! How can i wire all 4 subs to get a 4 ohm load or is it not possible?
Thanks for your're help!
dc
j.reed
Copper - Posts: 716
Posted: February 18, 2010 at 10:20 PM / IP Logged
what ohm are the coils?
wiring options for 4 12 dvc's? -- posted image.
jiggad69
Posted: February 19, 2010 at 9:55 AM / IP Logged
sorry! They are 4 ohm coils on the subs. the tarantula amp can handle 2-8ohm stereo and 4-8ohm mono. I want to hook the speakers up to run mono@ 4ohms. One other question...if my amp is rated at 1600watts at 4ohm mono....what would the amp put out if i ran the 4  4ohm dvc subs at 8ohms. i see how i can wire them to get an 8ohm load, but not 4ohm! will that be half the power? 800 watts mono?
Derek
dc
j.reed
Copper - Posts: 716
Posted: February 19, 2010 at 4:37 PM / IP Logged
Your best option using all coils with that amp is 8 ohm bridged. Yes you can figure about half the full output of the amp.
If the SUBS can handle it you could wire just one coil of each sub to get a 4ohm bridge making full power from the amp, but the subs will only handle about 50-70 of there rated rms that way, but if they can handle that much power it could be done that way. 4 single 4ohm coils Option 2.
jiggad69
Posted: February 19, 2010 at 5:02 PM / IP Logged
the subs are rated at 700watts rms. so if i run all 4 @ 8ohms....my amp will be pushing 800 watts to all 4? the amp is rated 1600watts rms @ 4ohm mono.
Thanks again Mr. Reed for your're quick replies.
I just wasn't sure if there was a way to series/parallel the voice coils to somehow come up with a 4 ohm load!
dc
j.reed
Copper - Posts: 716
Posted: February 19, 2010 at 5:45 PM / IP Logged
The amp will put out 800rms at 8ohm roughly. for 200rms per sub. You should be fine power wise if you only use 1 coil per sub wired to get your full 1600rms at 4ohm if they are 700rms per sub. That would be about 400rms per sub. With proper gain settings you should be fine.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
