sub box, 2000 chevy extended cab
tj546
Posted: May 12, 2010 at 11:07 AM / IP Logged
  I have 4   12" earthquake LS  subs   going in my 2000 chevy extended cab truck.  the box is 38w 26t 18.5d=8.79qf   the port is 9.5tall 12 wide and 13.67 long. the box dosent  sound good at all loud as hell in my shop but sounds like hell in my truck. i have more than enough power for these subs just could use some help with this. oh the subs are facing up vented out the front of the box.
tj546
Posted: May 12, 2010 at 11:18 AM / IP Logged
the subs are older but new ive had them for a while. the vent tuning is 43 hertz
tj546
Posted: May 12, 2010 at 12:02 PM / IP Logged
i need helpwith this please!!!!
eric21
Copper - Posts: 49
Posted: May 17, 2010 at 10:12 AM / IP Logged
I have a crew cab with 4 12" alpin type r's and had the exact same problem - it sounded like garbage even with 3000 watts. I had a center port with the
sub box, 2000 chevy extended cab -- posted image.
subs around it like in the picture. It sounded best pointed up but still not very good.
My next box I built had the 4 12's along the bottom with 2 areo ports like the picture below
This box sounded much better than the last and sounded best pointed foward. The size was about 9cu.ft. net. I later shrunk it down to 7cu.ft. net, it lost some low end but picked up the high bass alot better.
I think what I would do if I was you is to build a box with the subs foward and one long port along the back top of the box. It may not follow the 7 to 1 rule with port dimensions but i've seen and heard it before and it sounded good. I would divide the box into 2 chambers, so 2 ports along the top back of the box.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
