correct way to wire alpine 9815?
neek804
Member - Posts: 18
Posted: July 11, 2010 at 4:58 PM / IP Logged
Ok I just got this deck and I've read many post about it and I'm just confused about when they say I need to wire it to the battery...because its installed in my 05 impala now and I can't even turn the volume up with out it cutting off I know I have to re ground it because I have my ground connected to the harness instead of metal..I'm hoping there is an easier way to wire this to get power instead of going to the Battery also if i do have to wire it to the battery what do I need and where can I get it from
neek804
Member - Posts: 18
Posted: July 11, 2010 at 5:26 PM / IP Logged
Well this topic title suppose to be correct way to wire a alpine 9815??? Ima a rookie can't edit yet but pls help
Platinum - Posts: 13,726
Posted: July 11, 2010 at 8:51 PM / IP Logged
Did you use the expensive wiring harness?  If so what brand and model is it?  Some of them do not allow enough current through the adapter to supply that radio.  If you did use one, you may want to connect the radio's yellow wire to the vehicle's constant wire before the harness.
neek804
Member - Posts: 18
Posted: July 12, 2010 at 8:12 AM / IP Logged
http://computershopper.com/best-prices/product/32432892/Car-electronics/Scosche-GM2000-Class-II-Car-Stereo-Replacement-Interface-Module-and-Harness
This is the harness i have i just want to know how to connect the 10ga amp kit to the radio I see that It has a yellow wire with a box on it I'm guessing it's a fuse
Posted: July 13, 2010 at 3:05 AM / IP Logged
Have you tried connecting the Radio's Yellow wire to the vehicle's Orange wire before the Scosche piece?
haemphyst
Platinum - Posts: 5,059
Posted: July 13, 2010 at 9:44 AM / IP Logged
The CORRECT answer has not changed...
I got that information from Crutchfield, which gets their information FROM ALPINE! If the manufacturer of your deck tells you that you need to run a power lead from the battery, you'd be well advised to follow that recommendation. If it's shutting off, you probably didn't follow the instructions. They are "instructions", not "suggestions".
neek804
Member - Posts: 18
Posted: July 13, 2010 at 12:30 PM / IP Logged
I'm trying figure out connect it to the 10 gauge wire to connect it to the battery?
