ground question?
equalizir
Copper - Posts: 71
Posted: April 19, 2003 at 9:32 PM / IP Logged
hi guys,just wanted to know in a three amp setup do i need to have more than one ground point?
Cletis
Copper - Posts: 59
Posted: April 19, 2003 at 10:16 PM / IP Logged
No, just make sure that you pick a good place to ground them, and make sure that it is a secure connection into bare metal.  I think it is better to use the same point, that way you reduce the risks of ground loops.
wrencher_25
Copper - Posts: 101
Posted: April 19, 2003 at 10:20 PM / IP Logged
For sure, just make sure you're ground wires are the same gauge as your power wires, a lot of ppl neglegt that.
Andrew Weitzel
MECP First Class Installer
Big Purds
Silver - Posts: 574
Posted: April 21, 2003 at 6:45 AM / IP Logged
I typically use a wire one size bigger for my grounds...just to be sure there will be no grounding problems...
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
