alpine type r component speaker
tylerseefe
Member - Posts: 7
Posted: November 17, 2010 at 9:02 PM / IP Logged
I just ordered alpine type r 6 1/2 Alpine SPR-17S component speakers and i have herd that you are suppose to put the tweeters within 12 inches of the woofer is this true? and what should i set my amp to either full or high pass filter i am going to use the crossover that comes with it thank you any help is very help full
mcintosh-asylum
Member - Posts: 21
Posted: November 18, 2010 at 7:02 AM / IP Logged
you can put the tweeters anywhere you would like but the amp should be set on high pass and you can set your amp to different frequencies to get a little more mid bass out of your components and still have the amp on a high pass filter. if your put the amp on a full pass you could drown out the tweeter with frequencies that it cannot handle.
tylerseefe
Member - Posts: 7
Posted: November 18, 2010 at 8:01 PM / IP Logged
alright thank you
Platinum - Posts: 13,726
Posted: November 19, 2010 at 3:31 AM / IP Logged
Do you have woofers installed on your system?   Are your rear speakers 6 X 9s?  Do you know what it sounds like when a speaker is being beat to death from receiving too much bass?
I agree that you should probably set the crossover to High Pass.  But answering the above questionS will better help us help you.
tcss
Silver - Posts: 1,623
Posted: November 19, 2010 at 12:32 PM / IP Logged
You can put the tweeters anywhere? Really? That's just not true. Putting them closer to the woofer will give a better stereo image. Also highs travel avery narrow path so it is important to make sure there is no obstructions between the tweeter and your ear. Running the amp on full range will put signal into the tweeter that it can't handle? Really? He said he was using the Alpine passive cross over. The amps active cross over setting has nothing to do with the signal to the tweeter.
There is no such thing as free installation!
tylerseefe
Member - Posts: 7
Posted: November 21, 2010 at 5:27 PM / IP Logged
yes i have alpine type r 12 ported to exactly to spec
tylerseefe
Member - Posts: 7
Posted: November 21, 2010 at 5:43 PM / IP Logged
yes i have alpine type r 6x9 in the back
Posted: November 21, 2010 at 5:50 PM / IP Logged
With 6x9s in the rear deck and a woofer to boot, you definitely need to use the high pass filter of your amp or radio.  Why beat up your smaller speakers having them trying to produce bass when you have other speakers that can do that for you.
tylerseefe
Member - Posts: 7
Posted: November 21, 2010 at 6:27 PM / IP Logged
im not sure
tylerseefe
Member - Posts: 7
Posted: November 21, 2010 at 7:44 PM / IP Logged
is it okay if i place the cross over like 30 inches from both woofer and tweeter
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
