building portted box
jpadj22
Copper - Posts: 100
Posted: February 08, 2011 at 3:32 PM / IP Logged
Ok I recently bought 2 pioneer premier from my freind. The speakers look in good condition but unfortunately the box isin't.So i got to lookin around for boxes and id rather TRY and build one.Now I been doing research on this site on how to build one but im very confused.I want to know if anyone can tell me what do i need to take into consideration to get the dimesions for my box.
No better feeling then getting a remote start to work right!
DYohn
Platinum - Posts: 10,741
Posted: February 08, 2011 at 6:23 PM / IP Logged
The first thing you need is the exact model numbers for the speakers you want to use.
jpadj22
Copper - Posts: 100
Posted: February 08, 2011 at 7:25 PM / IP Logged
There the ts-W303R. Recomended enclosure .85-1.75 cubic feet.
DYohn
Posted: February 09, 2011 at 10:02 AM / IP Logged
Yes... based on the specs available on the web that woofer is going to sound really boomy unless it's in a very large enclosure.  In the recommended 1.75 cuft per woofer system vented at 19Hz you will get some decent SPL but not very good sounding music.  You'll also push it past peak cone excursion unless you keep the power down below 75 watts per woofer.
jpadj22
Copper - Posts: 100
Posted: February 09, 2011 at 11:07 AM / IP Logged
Thank for your reply Dyohn. So ill do the 1.75 cubic ft per woofer.Now i dont understand what you mean by venting the system at 19hz .I have to keep the power below 75 watts? Wow i thought i had gotten some decent woofers building portted box -- posted image.. Although i dont want to have a system thats  too crazy. Im a BIG DIY guy so i want to give this project a try. Im pretty handy with my hands I did alot of research on the tools i need im missing a couple but im going to buy them as soon as i feel i have enough to get this project rolling. With a little help im pretty sure i can do it thanks.
DYohn
Posted: February 09, 2011 at 12:17 PM / IP Logged
Venting = porting.  You need to design your port size for a 19Hz tuning frequency.  See the port size calculators on this site.
jpadj22
Copper - Posts: 100
Posted: February 09, 2011 at 1:00 PM / IP Logged
Thanks again. Ok so here is what i have ....
port width   1.5"
port height    2"
box volume being 1.75
tuning frequency  19hertz
My port legnth should be 11.3
So my divider in the the box should be 11.3 " long?
DYohn
Posted: February 11, 2011 at 10:33 AM / IP Logged
If you ask me that port will be much too small.  If you want to build a dual-chamber enclosre yes, generally it is easiest to use a slot port with a solid wall between the two chambers, but the wall cannot be the port length.  The port needs to ne open to the chambers.  Here's an example of what the inside of such an enclose typically looks like:
jpadj22
Copper - Posts: 100
Posted: February 11, 2011 at 1:45 PM / IP Logged
Wow!! thanks for the picture! I was thinking of doing the dual chamber enclosre like the picture above( at least i hope). Ok, so I think im ready to go thanks for all your help Dyohn. Im going to buy the materials this weekend weekend. Thanks
3ball1971
Member - Posts: 8
Posted: March 02, 2011 at 3:38 PM / IP Logged
Will that box design work with just one speaker?
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
