Fuse Question
sazaks
Member - Posts: 12
Posted: April 23, 2003 at 12:22 PM / IP Logged
I just finished installing adding an extra circuit with a fuse in the engine compartment fusebox. See Picture below. (Fuse sits in location 1 and new fused + power teminal is 2) Now my question is: If I wanted to run both my small amp (30A) and my HU (20A) could I just stick a 50 amp fuse in the fusebox and connect both to the same terminal? Or should I keep individual inline fuses there after?
Sazaks
Fuse Question -- posted image.
DjIQ
Copper - Posts: 107
Posted: April 23, 2003 at 1:01 PM / IP Logged
I would use one 30 amp fuse, a 50 amp fuse would not do you any good, the pourpose of the fuse is to protect the wire, so in the event that a device attempts to draw more current than the wire is rated for the fuse will blow and prevent the wire from catching fire
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
