buzz in my system
erock198
Member - Posts: 18
Posted: May 27, 2011 at 11:28 PM / IP Logged
My system has a nasty buzz from the alternator and I don't know where to start on finding the source.  It also seems to be cutting out my HU and cycling the power on and off
Erik
91 Camaro RS
I have a cdx-mp30 HU
Rockford symmetry epx
Rockford punch 200
Rockford punch 60
Rockford Punch 40
Rockford 6X9s
Rockford 4X6s
Punch P3s
XA300 AUX input
xmd1000 and xmdson110 for XM radio
I have an optima red top battery
ac0j
Copper - Posts: 121
Posted: May 28, 2011 at 12:24 AM / IP Logged
Probably a ground loop or a bad RCA cable.  Try to isolate where it is coming from. I would start by putting a jumper wire from the outer RCA shield to the chassis of the radio, see if that makes a difference.
mujahid
Member - Posts: 11
Posted: May 29, 2011 at 6:01 AM / IP Logged
are your power and remote wires separated from you signal wires
@0 Hertz Xpertz/Team SPL
erock198
Member - Posts: 18
Posted: May 29, 2011 at 11:22 PM / IP Logged
I think the first reply is correct.  I've been too busy to check it out but I think bad rca cables might be to blame.  most of the system has been professionally installed so I"m guessing the wires are run correctly but the AUX and the XM were added by me using some cheap rca cables.  I"m going to make some changes on memorial day and see if the problem is fixed
Erik
