single amp at 1 ohm vs two amps at 2 ohms?
kp5259
Member - Posts: 8
Posted: June 18, 2011 at 3:59 PM / IP Logged
Interested in opinions on some of the differences there might be between running one amp at 1ohm to get 1,600 RMS vs running two identical amps at 2ohm to get the same 1,600 RMS watts?
More specifically two DB Drive SPA1600d's amps vs only using one amp....they would be driving two kicker 12"l7's which are 750rms9(1,500RMS total) each.
Would running the dual amps give me better SQ or something? It would seem like running the two amps versus one would have to be superior in some way even though they would be resulting in the same output. Not sure?
haemphyst
Platinum - Posts: 5,059
Posted: June 18, 2011 at 7:00 PM / IP Logged
It would be the same output, but with less wasted heat, beter efficiency, higher damping and lower distortion.
Definitely a better option IMO.
kp5259
Member - Posts: 8
Posted: June 20, 2011 at 7:09 PM / IP Logged
thanks....that is sort of what i figured
mofo15s
Member - Posts: 13
Posted: July 13, 2011 at 7:32 PM / IP Logged
2 amps running at 2ohms would sound slightly louder and be clearer and better sound quality.
DYohn
Moderator - Posts: 10,741
Posted: July 15, 2011 at 9:51 AM / IP Logged
Loudrer?  No, not at all.  This is incorrect information.
