tuning ssf?
shadowm891
Member - Posts: 23
Posted: December 27, 2011 at 10:49 PM / IP Logged
hi guys have a question i have a box built which is 1.75 cubic feet tune to 32 hz and i was wondering how low can i set my ssf to for my sub.
DYohn
Platinum - Posts: 10,741
Posted: December 28, 2011 at 9:34 AM / IP Logged
Is the enclosure sealed or vented?
shadowm891
Member - Posts: 23
Posted: December 28, 2011 at 11:30 AM / IP Logged
it's vented sorry
stevdart
Platinum - Posts: 5,816
Posted: December 28, 2011 at 4:56 PM / IP Logged
You can't just set a control on a given mark on the amplifier.
Set the subsonic filter to the point where the woofer doesn't flutter out of control as you play test tones down to the lowest recorded tone.  Bring the loudness up to a point where you might reasonably use the system and watch the speaker.  If it flutters, an out-of-control sort of movement, gently increase the filter until the woofer behaves.
In lieu of test tones, use your most demanding music material.
