need some wiring zr1000/ solox 10
lazydayz
Posted: July 24, 2013 at 6:33 PM / IP Logged
so i have a kicker zr 1000 amp that is curantly pushin two 12" alpine type r's wired in 4ohm stereo working great but,.....i just got a box for my Kicker solox 10" DUAL 1ohm sub ( used to have 2 solox's wired 4ohm on same amp ).
So now i am unshure how i should wire just want to know for shur before i turn it on......im just guesing i need to run my amp bridged and my sub wired (option two in series at 2ohm load).....any help would be awsome normaly i would just take it to my installer but that will take a week.
Solo x 10", kicker zr1000.....1998 subaru rs2.5 coup
Platinum - Posts: 13,726
Posted: July 24, 2013 at 8:31 PM / IP Logged
Which speakers are you going to use?
Is this a 1 channel or a 2 channel amp?
What is the minimum safe operating impedance of the amplifier?
lazydayz
Posted: July 24, 2013 at 8:37 PM / IP Logged
1 solo x 10" dual 1ohm
lazydayz
Posted: July 24, 2013 at 8:43 PM / IP Logged
2 channel amp
bridged 1 or 2 ohm stable.
thanks
Posted: July 24, 2013 at 10:10 PM / IP Logged
According to the information at crutchfield, that amp is 2 ohm stereo or 4 ohm mono stable. You can not safely run only that woofer unless you run the coils in series and use only one channel of the amp.
lazydayz
Posted: July 24, 2013 at 10:51 PM / IP Logged
You got that backwards.......4ohm stereo 2ohm bridged.....its hooked to the type r's now 4ohm stereo.....but it will do 2 ohm stereo aswell.
Ween
Platinum - Posts: 1,368
Posted: July 24, 2013 at 11:05 PM / IP Logged
kicker zr1000.. 250W x 2 @ 4 ohms, 1000W x 1 @ 4 ohms,
500W x 2 @ 2 ohms, 1000W x 1 @ 2.67 ohms,
350W x 2 @ 1 ohm, 700W x 1 @ 2 ohms.
as taken directly from kicker zr owners manual, january 1997.
