fm reception problems
ric008
Posted: August 08, 2013 at 3:24 AM / IP Logged
Hi all, I have a few questions on FM reception. I had a BWM 318ti with a factory radio and i installed a aftermarket amp and sub. when i switch the amp on my fm reception falls away. this also happened to my new Polo Vivo and New BMW 320i. I also had the same problem with a mirror that i installed with a screen and a rear view camera, as soon as the camera and screen comes on the radio reception drops. it ia almost as if the aftermarket electronics interferes with the reception. I installed a aftermarket navigation radio into a Triton and also experienced bad reception.
ib6469
Member - Posts: 7
Posted: September 08, 2013 at 11:33 PM / IP Logged
Slow down , to much info at one time . The BMW'suse an amplifier on their antenna so make sure your not turningthe ant. off . OK on the other vehicles just email me and I will try to get you an answer .
Platinum - Posts: 13,726
Posted: September 09, 2013 at 8:42 AM / IP Logged
Class D amplifiers do use high frequency oscillation and are likely to generate RFI. Radio Frequency Interference. The cheaper amps are more likely to give you problems over Reputable companies.
ric008
Posted: September 11, 2013 at 6:49 AM / IP Logged
ok, and the reception is also bad on navigation radio's, could it be that the radio screen or something in the radio cause interference with the reception?
