2 or 4 Ohm amp/8 Ohm Sub
Nestamarley
Member - Posts: 12
Posted: May 20, 2003 at 5:52 AM / IP Logged
I hav e been trying to find info on hooking a DVC sub in an 8 Ohm configuration to a 4Ohm / 2Ohm stable amp.
Are there any pros, cons, dangers, and how does it change the amps performance?
"In this bright future you cant forget your past"
greenbroncoguy
Copper - Posts: 299
Posted: May 20, 2003 at 5:57 AM / IP Logged
when you have 8 ohms, there is more resistance than there would be if there was only 4. your sub will not be getting as much power as it was if it was only 2 or 4 ohms. if it is dual voice coil, you can hook it up to be 4 ohms and that is the way that i would do it.
greenbroncoguy
Copper - Posts: 299
Posted: May 20, 2003 at 6:14 AM / IP Logged
by the way, what type of equiptment do you have- amps, speakers, and head unit? just out of curiosity?
Nestamarley
Member - Posts: 12
Posted: May 20, 2003 at 12:52 PM / IP Logged
  I have a 660 rms power acoustik fahrenheit amp and a 600W rms15" volfenhag sub in a 5.25 cu. ft. wedge box.
submaster420k
Member - Posts: 9
Posted: May 20, 2003 at 2:57 PM / IP Logged
with a dvc subwoofer think of it as two 4 ohm subs just hook it up like you were hooking up 2 4 ohm subwoofers
greenbroncoguy
Copper - Posts: 299
Posted: May 20, 2003 at 4:03 PM / IP Logged
yeah, just put the positive and negatives of each coil in the same spot on the amp
wvsquirrel
Gold - Posts: 1,237
Posted: May 20, 2003 at 4:59 PM / IP Logged
what's the model number of the amp?
The reason I asked is if it is a mono amp then you could wire the sub to 2ohms safely like this.
2 or 4 Ohm amp/8 Ohm Sub -- posted image.
But if it is a 2+ channel amp then we'll need to figure out something else because most 2+ channel amps are only 2ohm stable Stereo and 4ohm stable Mono. Hard thing to do with a single 4ohm DVC (unless you want to risk independant wiring).
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Nestamarley
Member - Posts: 12
Posted: May 21, 2003 at 9:45 AM / IP Logged
FARENHEIT Q21500
1500 WATT Amplifier
Heres the model # and specs on the amp. and the sub is a dvc but with each voice coil @ 300w rms I should be fine just giong with the plain jane 4ohm config. right?
Specifications
2 X 400 Watts @ 2Ohms RMS
2 X 330 Watts @ 4Ohms RMS
1500 Watts Max Bridged
Freq Response 10 - 30,000 Hz
THD: 0.02% S/N Ratio;: 97dB
wvsquirrel
Gold - Posts: 1,237
Posted: May 21, 2003 at 9:38 PM / IP Logged
Your amp is listed as being 2ohm Stereo stable, but not 2ohm Mono stable. Which means you can either wire each voice coil independently to its own channel at a 4ohm load on each channel giving apx 330RMS to each coil (which is not recommended though, read more here on the dangers of independent wiring), or you can wire the sub into a bridged 8ohm load which will give you apx 400RMS to the entire sub.
IMO, With your current equipment you would be better off (and safer) wiring to the bridged 8ohm load for 400watts. You would be underpowering the sub, but you wouldn't run the risk of it tearing it apart by using different input signals. Here's how you would wire it to an 8ohm load...
Squirrel
D148l0
Copper - Posts: 57
Posted: May 21, 2003 at 10:11 PM / IP Logged
Nestamarley, as wvsquirrel wrote, wiring the VC's separately is absolutely the last thing you should do...
d148l0
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
