Cabling
nedgeworth
Silver - Posts: 264
Posted: May 22, 2003 at 5:35 PM / IP Logged
I'm deciding on weather to use some leftover 10ga power cable i have lying around for the speak wiring to my subs. How citical is it that i use wire specifically designed for speaker as to opposed to using power cable?
bberman1
Gold - Posts: 2,314
Posted: May 22, 2003 at 5:41 PM / IP Logged
You should not have a problem using it just be sure it's  the correct gauge for your application. If you want to make the install a little cleaner you can zip tie the 2 cables together and they will look like one. Just be sure to mark which cable is which, I see all to often people hooking the wrong cables up because they are all the same color and cant tell the difference between them.
nedgeworth
Silver - Posts: 264
Posted: May 22, 2003 at 5:45 PM / IP Logged
Ok. I was just worried that i might be losing a little bit of signal there. I should be right 10ga for 200rms sounds good too me. Thanks again
Big Purds
Silver - Posts: 574
Posted: May 22, 2003 at 6:16 PM / IP Logged
you shouldnt encounter any problems at all...wire is wire, no matter how you look at it...the only real differences are sizes and cosmetics...
just be sure that its OFC (oxygen free copper) and you are set...
bberman1
Gold - Posts: 2,314
Posted: May 22, 2003 at 6:17 PM / IP Logged
10 ga for 200 rms is way too large and a bit of overkill but it will work. But your welcome
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
