Engine Noise Through Speakers
Clubscene
Member - Posts: 8
Posted: June 01, 2003 at 6:50 AM / IP Logged
As above but really only occurs on Radio. It is barely noticable on CD (passenger front left speaker only). The car is a Subaru Impreza with a Pioneer 8400 Head Unit running an Alpine 6 Speaker Sound System.Its not the Head unit, as it does this with the original 1 as well. The strange thing is when I put the Pioneer in at first it cured the problem but the Pioneer died due to a dead short in a speaker cable. It was sent to Pioneer for repair and when I got it back, it started doing the same thing as the original head unit, dreaded engine noise.
Clubscene
Member - Posts: 8
Posted: June 01, 2003 at 6:51 AM / IP Logged
Any simple soloutions?
DYohn
Platinum - Posts: 10,741
Posted: June 01, 2003 at 7:44 AM / IP Logged
Try running new speaker wire, especially is it is only one channel.
Clubscene
Member - Posts: 8
Posted: June 01, 2003 at 8:21 AM / IP Logged
No its only 1 channel on CD, on Radio its all channels!
Big Purds
Silver - Posts: 574
Posted: June 01, 2003 at 10:58 AM / IP Logged
check all grounds and make sure they are OK...
it *could* be your alternator creating interference, which the radio *could* be more sensitive to thus resulting in the difference between radio and CD...have you installed an amp?
Clubscene
Member - Posts: 8
Posted: June 01, 2003 at 11:23 AM / IP Logged
No amp installed. How do I check the grounds?
