Switched 12V at Fuse Panel, 2011 GMC Terrain
jh1973
Copper - Posts: 50
Posted: September 20, 2018 at 11:42 PM / IP Logged Link to Post Post Reply Quote jh1973
I'm using the stock HU so my DSP gets turned on by a switched 12v circuit in the interior fuse panel.The slot was empty and I added the circuit.The DSP then turns on 2 amps and I now want to add 2 fans to cool the amps.Can the switched circuit handle 2 more loads like that or should I use a relay?I'm not sure how many amps the fuse panel circuit can handle so thats why I'm asking.Thanks!
Rumors of Bob but never Bob......So what is it you tell people you do these days Bob?
eguru
Copper - Posts: 340
Posted: September 21, 2018 at 9:13 AM / IP Logged Link to Post Post Reply Quote eguru
What car/HU/DSP are we talking about? What are the specs on the fans?
jh1973
Copper - Posts: 50
Posted: September 21, 2018 at 9:22 AM / IP Logged Link to Post Post Reply Quote jh1973
2011 Terrain,stock HU with Zapco Z8 IV processor,2 Zapco STX amps and fans are rated to draw .19 amps.
jh1973
Copper - Posts: 50
Posted: September 21, 2018 at 9:45 AM / IP Logged Link to Post Post Reply Quote jh1973
Just using common sense would tell me that I could easily use the circuit from the fuse panel because the other fuses in the same column are 20A and 10A. The 5 components I'll be powering probably won't even amount to 1A of draw. Is my thinking correct here?Approval from an expert here would be appreciated,thanks.
eguru
Copper - Posts: 340
Posted: September 21, 2018 at 12:29 PM / IP Logged Link to Post Post Reply Quote eguru
Those are pretty small fans - so you are correct - should work fine on existing circuit.
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
